Dim3nsioneer 556
If you want an original Ulticontroller, you might want to get in contact with an Ultimaker reseller as the parts are still available (just not as a kit anymore).
But @neotko's advice is probably the cheaper way.
Edited by GuestIf you want an original Ulticontroller, you might want to get in contact with an Ultimaker reseller as the parts are still available (just not as a kit anymore).
Edited by GuestThank you, I'll look into that.
neotko 1,417
You can use reprapfullgraphics discount smart controller, that’s cheaper and works nicely using @amedee firmware builder
https://bultimaker.bulles.eu/
You would just need to select the reprap controller and, unless you made a mod, build the firmware through that website @amedee has
