Hello Neotko,
Thank you so much for answering me.
I ask you a little patience with me, because I'm completely new to ultimaker 2 extended +.
Please, let's go step by step ...
1- I have to change in the settings of Cura2.7 the gcode flavor to Regrap.
2- Changed to Regrap, what exactly do I have to do? I am confused...
Where do I have to edit? In Start GCode or End Gcode or both?
3- In the case of ultimaker 2 extended +, which of the two would be better to edit (prime more / less or retract more / less)? I just found the retract in End GCode and the prime I did not find! For what value do you advise me to edit?
4- Do I have to add or edit more things in Start GCode and End Gcode than what you told me?
5- After you instruct me in the previous steps, do I have to update the Firmware? Because I had updated this week the firmware with GCode Flavor set to Ultimaker2.
Or am I saying something completely wrong and this firmware business is completely independent of the GCode you choose?
6- What will happen to the Material settings in Cura2.7? Can I still use it normally or from now using the Regrap do I have to define by the advanced settings that will appear?
Sorry about so many questions but...
Thank you very much for your patience and attention.
Change the ultigcode to reprap on the machine settings and then you can change anything directly on cura. As soon you change it you will see start/end gcode and by default it’s just like the one the machine does, but also you can edit it to prime more/less or retract more/less at the end of the print.
Griffin flavor is the one um3 uses btw. You need reprap flavor to edit retraction etc from cura.
neotko 1,415
