Check out the Cura 3.5 release notes in regards to excessive moves.
Hello @Deneteus
I just downloaded and installed Cura 3.5
Now I'm using Ideamaker as my preferred slicer
I tried to slice the same stl with the same settings where possible
Ideamaker makes my gcode 47600 lines while Cura 3.5 makes a 68600 lines one.
I like the way Ideamaker slices my stl and travels/movements seem to be ok
I must check what this new Cura version makes but the gcode volume seems to be a little too much..Bie
@Piero70
The print time estimates are based on your printers acceleration settings entered into Cura. To reduce the print time estimate you have to enter your printers acceleration settings into Cura. It's not based on the lines of code that you see within the GCODE file.
The issue with unnecessary moves is based on what some of the settings were causing the extruder to do. Not knowing what settings you chose doesn't give anyone an idea of what the problem is. You would need to post your Profile settings file, the STL, the current gcode files, and your printers firmware settings for anyone to give you an idea of what is really going on.
How to export profiles: https://ultimaker.com/en/resources/20441-manage-profiles
This is where you would post your Issue: https://github.com/Ultimaker/Cura/issues
Here is an example: https://github.com/Ultimaker/Cura/issues/3323
Check out the following posts for specifics:
Edited by Deneteus- 1
burtoogle 516
Hello @pieri70, I think the difference is that Cura has the fill gaps between walls option enabled and this produces zillions of little line segments. Try turning that off and see if it makes a difference. Looking at the s3d gcode, it doesn't look as if the gap is being filled there. Hope this helps.
