Does Cura set temperature correctly?
kai
Posted · Does Cura set temperature correctly?
I attempted to adjust the materials parameters for a filament, so I created a new material with extruder temperature set to 230° and bed temperature to 0°. However, when printing, I noticed that the bed was hot. Looking in the generated gcode I could not find the expected temperature setting commands (M104 and M140), so I presume the print proceeded with the defaults of the printer.
Is this the expected behaviour?
Environment: Cura 2.7.0, Ultimaker 2+
