kmanstudios 1,073
Where do I find the project logs? I can give you a link shortly for the project file after I dig it back up and verify it again.
The logs generated by Cura and the project is seperate.
I am in the process of doing a job, but when I get the chance, I will note the oddness I found. Although, where are the logs you need me to collect?
OK, here is what I have been able to document, and, it just may be my system.
First, I loaded a project file after another project file and got this:
Please note that infill density still reads zero while slicing with infill.
Then when, again, just loading a project file straight, it gives this:
It says it is going to update file. But settings do not change. I also cannot uncheck the hollow objects box.
Note that I can change infill densities and that will accept changes.
But when changing the material selection it will make the change:
Hopefully this will help. I am PM'ing you with the link to the project files themselves. I have not decided how 'open' I want this to be at this time, hence the PM with link.
nallath 843
You're the first I've heard about this. Can you share the project files / logs?
