I think those things that hold the bowden tube to the ultimaker might be available very cheaply at plumbing stores. Someone mentioned this once. So you might be able to get one today and be back up and running sooner.
Thanks - I've just tried the test you described. One hand pushing the filament and the other in contact with the Bowden tube at the extrusion end. As soon as I started to push the tube started to move out of the head. Not much effort at all.
And thanks for the plumbing store tip - I'll try that this morning.
Mike.
Plumbing supplies didn't have it but the guy suggested a shop that sells domestic water filters. I went there, showed the fitting which they recognised. Asked how many I wanted - I said half a dozen - he said that we don't carry them, except as part of a kit. But, we do scavenge them off old filters and he gave me two!
Works at treat, even on this Bowden tube which has been through a bit. Might be to the good, I suppose, roughened up the surface.
I think the fitting is ex US as the tube measures closer to .25" O/D and .125" I/D than it does to any metric size. If only we could track them down....
Printing as I write.
Happiness reigns!
Mike.
gr5 1,971
Something is seriously wrong. I've pushed filament through manually (not using the gearing) with my full strength and the bowden tube didn't come off. I'd say maybe 80 pounds force. I had to hold the feeder down with one hand and push on the filament with the other. So I assume you can pull on the bowden (either end) with 80 pounds force and it will stay on although I'm afraid to try.
