It's not exactly caused by the part shrinking.
It's because as it extrudes, PLA sticks to itself like snot. Like a liquid rubber band. And it is also shrinking rapidly while still liquid so it is pulling inward. and when you go around any corner it pulls inward. It's a little worse on corners. It gets better as you get farther from the heated bed. It seems to help if you have double pass walls (e.g. line width .4mm and shell width .8mm) as the inner wall helps hold the outer wall in place.
1
geert_2 557
This is a normal effect on all similar 3D-printers. The filament is still molten or somewhat flexible when laid down. When the nozzle is printing a corner, as in tight circles around holes, it pulls the molten filament to the inside of the curve.
In small holes this is even more visible: a 3mm hole may come out as a 1.5mm hole. It also depends on printing speed and temp.
Solutions could be: change the dimensions in the design, or go through the hole with a drill.
rebekah_harper 60
hiya,
I do exactly what Geert_2 is suggesting. any part that needs exact fitting I reduce by half the nozzle size.
works fine for me
Bex
gr5 2,094
I make all my holes .5mm larger than desired. Vertical holes. Horizontal holes are fine.
db112358 0
I noticed exactly the same thing.
My 18mm desired outside diameter prints as 17.8mm and my internal desired diameter of 10mm prints as 9.8mm due to material contraction.
I added a horizontal offset of 0.4mm to exaggerate the effect and ended up with 18.6mm outside diameter and an internal diameter of 9mm. It's no coincidence that both dimensions moved exactly 0.8mm as Cura has added an offset edge of 0.4mm to the outside wall but has also added an 0.4mm offset to the inside wall making the hole smaller.
The only way to do it is to perform non-uniform scaling along the X and Y axis in the scale settings rather than use the horizontal offset.
It is clear that Cura is adding an
