Are Igus Drylin bearings ok to replace standard z axis linear bearings UM2 ?
Posted
· Are Igus Drylin bearings ok to replace standard z axis linear bearings UM2 ?
The problem with Drylin igus for round shafts it's that you would need to also use Igus shafts to make them work, because they are made for X tolerances, and if to that you add that you got them on ebay well... probably they are made for a clamp system that fits them so they won't work nice on your printer. IMO Igus it's nice but doesn't work with round shafts, on prusa the bearings are on a different situation where they are inside a bearing holder that press them etcetc. It's different.
Misumi flanged bearings work great, dunno where to get them on UK. But https://www.technobotsonline.com for me has deliver really good stuff, specially nice hotend LMU bearings, dunno if they have flanged bearings for the Z.
Edit. Yea they don't have the LMK12LUU but the LMK12UU (short version). Maybe you can get a friend with a company to order them for you to misumi, the C- (Cost effective) ones are decently priced (but not cheap) and they work great for me.
Posted
In addition to what Neotko said, the igus version doesn't have the right size. The standard/misumi version is a 12x21x57mm, the igus version instead is 12x22x57mm. The difference in the outer diameter means that the platform cover can't be mounted.
Here is the source, the version I'm talking about is the FJUMT-02-12 and they cost 29.78 € each, not so cheap.
Posted
Or you can turn to your local Ultimaker reseller as I think they have switched to Misumi bearings now. At least the Swedish reseller gave me Misumi linear bearings as replacements for the Z-axis when I told them that the ones delivered with my printer were crap.
2
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
neotko 1,417
MarcoUbtz 15
nilrog 103
