Posted · How to migrate resource files from Windows to Linux Cura?
I'm migrating Cura from Windows to Linux version.
I've some custom resource files to copy to Linux Cura:
\Program Files\Cura 2.7\resources\meshes\some_custom_printer.stl
\Program Files\Cura 2.7\resources\definitions\some_custom_printer.def.json
\Program Files\Cura 2.7\resources\extruders\some_custom_exdruter.def.json
... and so on.
Therefore the corresponding directories on Linux aren't accessible as they are temporarily created at runtime.
How do I add the files to Linux Cura?
    • 1 year later...
    I'm up against the same issue with 3.6...  Trying to import my Bibo Touch .def files.  Can't figure out how to do that.  Did you find a way?
    Oh! Sorry, I missed this topic.
    On linux Cura has 2 locations where the files are placed
    So if you want them for 3.6, the config files need to be in ~/.local/share/cura/3.6/
    The cura.cfg (preferences) and the plugin.json need to be located in ~/.config/cura/3.6
    • 1 year later...
