More and more engineers in the USA and UK are switching to the metric system. Once you are used to it, it is sooooo much simpler and more logical than imperial units with their weird multiplying and conversion factors, and where some "units" have totally different dimensions, depending on where you are (such as gallons, if I remember well). It is just a question of time before everyone uses the metric system. So you can better be among the first than among the last. You will not regret it.
macks1819 1
Oh well, figured it out, just going to have to embrace the metric system and learn to love it.
Dim3nsioneer 528
That's the best of all solutions
(Please convince the rest of your Great country to do the same.)
Meanwhile you might find a plugin for Cura 2.7 interesting which you can install by the new plugin browser; it's called "Barbarian plugin" (if you want to blame someone for the name, @nallath might be a good address
