Thanks for the video!
It did clear up some of the things I was not sure about still getting slight edge on the first layer but will repeat the process again and will see how it is going to turn out!
Hi @drbrcho, can you elaborate what 'the bottom is not flat' means? Does it mean you see warping, or are there some irregularities in your first layer which make look like 'scratches'?
In any case, a photo of what your first layer looks like, would be helpful.
What filament are you using? If you have warping, this is important information.
If you are having elephant feet, and you are using Cura 2.7, you could look into the setting 'Initial Layer Horizontal Expansion'. Good luck!
Here is a picture
Not from my printer and it does not look so bad but similar. Not sure how to explain it. No matter how many times I am leveling the bed manually or using the auto level always comes like this. I am still using the original ultimaker filament the printer came with. Yes I do use latest cura 2.7 will check the setting!
ErenKaratepe 1
I found a useful video on the youtube. Simultaneously with this video, it may be helpful to repeat the steps.
If ıt does not solve this problem. I have a simple solution. Choose platform adhesion type raft. This is a quick solution.
Edited by GuestI forgot to add a link.
