Bunnyman21 11
@gandy @jomeier No problem, I put the link below. Still had some things I wanted to fix before uploading which are done now. Note it doesn't detect directories automatically for Mac or Linux yet, but can detect Cura for Windows just fine. For Mac/Linux, just give it the file paths. The script should work on a Pi too, but better to use command line for that rather than GUI.
https://github.com/DA-Osborne/Spool-Maker
@gandy A cura plugin would definitely make it easier to match up Materials. Looks like Cura has a page dedicated for making plugins that work within Cura I need to read sometime. For now the CuraMaterial.py file can load all installed materials. (in a crude sort of way)
I normally run it from within Visual Studio Code, as double clicking it doesn't always work. I added a resource loader so you can also run pyinstaller to make an exe version if that's easier. Otherwise, the main function allows the creation of a spool by simply filling in the required variables at the bottom of the NFCSpool.py file. (The GUI is launched from the SpoolMaker.py file on the other hand)
I have used it for some PolyWood material so far by winding it onto a depleted Ultimaker spool, and overriding the tag with the correct ID and remaining length. Very useful for knowing if there is enough material left!
- 1
- 1
Top Posters In This Topic
31
11
10
7
Popular Days
Nov 8
10
Mar 28
7
Jun 26
6
Nov 9
5
rachael7 31 posts
Hiabst 11 posts
Bunnyman21 10 posts
Monroe07 7 posts
Popular Days
Nov 8 2022
Mar 28 2024
Jun 26 2021
Nov 9 2022
Popular Posts
gandy
@gmeardi If you can love the solution depends on how much you are willing to stretch 'easy', so here we go. Before working with the Ultimaker S5, I've never really put my mind to NFC techn
Bunnyman21
@gandy I came across your example scripts for creating and writing spools while trying to write my own tags for some 3rd party spools. I just wanted to say the scripts worked really well! (I ended up
dainon
I use the S5 as a hobby; if someone's use case is similar to mine (i.e., small set of spools/colors), you can try this location for NFC tags and re-write to them when you replace a spool.
Posted Images
jomeier 0
oh man: Could you share that, please? I'm getting crazy with not knowing how to use the scripts.
Thanks a lot,
Josef
