DidierKlein 729
With the printer shut down
Raise your build plate by hand (turn the screw)
Check at the bottom, there's a hole where the plate pushes a screw that is activating the z endstop switch.
Check in that hole if you have something (debris most likely) that is preventing the z-switch to be activated.
Or check that there's actually that screw that is activating the switch
Dim3nsioneer 557
Do you happen to have a short video of that awful noise?
