Posted · Bug in Cura 2.6.2 on skirt lines
I just discovered a small bug in Cura 2.6.2, the skirt lines are printed IN my model:
5a333fac56861_Capturedecran2017-10-01a15_15_42.thumb.png.dbf57a9324c155d0e70a62804e72195f.png
The model printed can be found here:
https://www.thingiverse.com/thing:2513624
Here are the settings used for skirt:
5a333fac9bfbd_Capturedecran2017-10-01a15_15_55.png.554f5dd8f2622d5b5b2cebc08b37c758.png
Yes I can change the distance, but I would like report it to the developers, i'm not sure to be at the right place.
Thank you
    Hi, I just tried slicing this with the current development code and it's fine. However, if I click on the object and slightly raise it above the build plate by setting Z to 0.2 then I see exactly the same result as you show above. Perhaps, your object isn't actually resting on the build plate?
    oups ... yes you're right, just updated to 2.7 a the bug is not anymore present, thank you for the help and sorry for this useless post ;)
    5a333facabe53_Capturedecran2017-10-01a21_52_17.thumb.png.aae9db1bd1c8b311451ad95b881b3594.png
    PS: The download of the last version is impossible from my computer, server does not answer (I had to download it from my dedicated server first ... )
    Also, according to freecad, the model is buggy.
