yeah, the initial retraction settings were a bit off the mark, but that’s not what I meant. Not saying I don’t appreciate your tips, it was helpful during tuning!
What i meant is the basic behavior of Cura. Take this example:
Cura will first print the outermost (red) wall, then the outermost-inner (green) wall, then travel to the innermost-inner wall (blue arrow), and continue there. During the blue-arrow, no retraction is triggered, and it oozes like hell. This is bad, since we’re on the first layer: The bottom-solid is going to be printed onto the oozed-across line which has considerable thickness. This destroys the evenness for the 2nd layer, and also the visual quality of the bottom of the part …. Also, this also happens for solid-top, where the ooze-lines then show through the roof, impacting visual quality and smoothness of the parts roof again.
This is — I fear — not tuning related, is it? If there’s a setting in Cura that alters this behavior, I’d be glad to know which (maybe I’m just blind, overlooking it …).
Anyhow, thanks a lot for your help so far!
-NebuK
gr5 1,506
I don't have much to help you - if you print colder you shouldn't care so maybe lower the temp by 15C just to see what happens. Even better go into the TUNE menu and lower the temp 5C at a time while printing and mark with a sharpie where you change the temp to see what works and what doesn't. You probably will also have to slow it down so set feedrate to 50% as an experiment also.
Having said that, 8mm retraction is too much! Unless your bowden is 2 meters long, 4mm should be plenty. Is this a bowden printer (if so around 4 to 5mm retraction - if not then around 1-2mm).
If you retract so much that air gets into the nozzle then the retraction will cause more problems than help. I'm assuming you have bowden printer - you want to retract enough so the filament at the top of the bowden arc moves from pushing against the inner top of the bowden to resting on the bottom of the arc of the bowden. If the filament actually pulls out of the head at all then that's too much retraction. You just want to relieve the pressure.
