Printing problem after a factory reset
Posted · Printing problem after a factory reset
Today I did a factory reset and after that I started to have the following problems.
The printer creates problems after printing the first layer.
The subsequent layers of filling are all detached one with each other.
I tried to lower the current values of the stepper motors first to 1100 mA and then to 1000mA but nothing changed.
Where is the problem?
    • 3 weeks later...
    There are many things that go back to "default" when you do a factory reset including all the steps/mm settings. Particularly, like conny_g, I'm guessing you messed around with Z steps/mm long ago? Does that sound possible?
    Alternatively it could be the extruder steps/mm.
    I would calibrate both. Move the Z some distance such as 100mm and then check that it moved the correct amount. Repeat with the extruder.
