I believe prevention is the way to go, so I always keep my PVA and Nylon sealed, also during printing. This means you loose the functionality of using the tags on ultimaker spools, but I don't mind as I'm used to set material type manual anyhow, as you need to do it for non ultimaker materials.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
ultiarjan 1,223
I use this;
https://www.youmagine.com/designs/drybox-for-pva-ultimaker3
To 'repair' your filament you can use something like this, I never had too...
https://www.makerpoint.nl/nl/printdry-filament-dryer.html
