I'll move your thread to modifications and hacks, you may get more replies there.
From what machine do you want to upgrade to an Ultimaker 3? The print cores have a pretty long lifespan. If you do not wear down the nozzle you should be able to use it for a very long time.
I currently run UM2 and UM2+ i find the Teflon needs to be changed anytime between 200-500 hours. I have had them last longer but it can be as short as that.
Does the print core not use teflon then? How long are people finding they last for?
What other parts wear? Currently on my machines the teflon is really all i am changing, occasionally other bits have gone wrong but some of them have been running at close to 10k hours.
There is almost no information i can find about it online.
SandervG 1,519
