I have pretty good luck with ABS and PC on painters tape as long as I wipe and dab dry the top of the tape with isophrol alcohol, I add glue stick to the tape, kind of thick and lightly spread with a paper towel. I start the speed at about 90% and after the brim is done I go back to 100%speed. After the brim is done I tape the edges of the brim
down with painter tape.
Also have to have the front enclosure as mentioned,
tinkergnome 918
Have you tried the adhesive sheets? They are claimed to work well with PC. A front enclosure doesn't hurt either.
Edited by GuestLink to post
