err so after a year of owning my Ultimaker I did not realise this, I thought the material settings were in the Gcode, I do not normally have problems printing but this would explain some issues I had when changing to exotic materials....
I think that this highlights that this "hobby" will remain exactly that until it becomes more consumer friendly (and by consumer I mean non tech-savvy). I do not have the time or inclination to sit on forums in order to know everything about Gcode and manual settings etc, I just want to design something and print it for functional items. I would say more than half the items I design end up printing well and being used, 25% are concepts and there are always a couple of failures, the latest being Brassfill and I am thinking that may be because of the material settings now
I honestly didn't know that after you put the material settings into Cura you need to export/import it to the printer, even if that is the case I would expect that to happen when you plug the computer into the printer for an update??
DidierKlein 727
Hi you can find the explanation here:
https://ultimaker.com/en/resources/20982-custom-materials-ultimaker2-plus
