Thanks, that pretty much explains everything. BB's are built differently and specifically for the PVA and other support materials which I've used to great effect. Cool.
And glow in the dark is abrasive? I've just read this, literally 5 minutes from setting of a 4 hours glow material print! Oh well.
How abrasive? What guidelines are there for these 'filled' materials? I'm not so interested (at the moment) with the metal fills, but I do want to start with the wood. I'm guessing you advise using the .8 cores. Are you also suggesting that I should be using a cheaper less quality machine where I'm going to destroy nozzles that cost a few quid instead of cores that cost £90?
I have ordered a CR-10 for just this reason, or at least 'banging out' stuff where the quality isn't as demanding as the work intended for the Ulti.
And on brands, with pretty much default settings, and without forensic testing, I've found the RigidInk PLA materials the most problem free. Apart from your Nylon which I simply cannot make go wrong, it's superb.
But I did buy the Ulti with the intention of making many different things in many different materials, so if you have a list of those materials you feel unsuitable for this printer please let me (us new folk) know so I don't go buggering up expensive hardware unnecessarily.
Many thanks.
SandervG 1,405
Hi @Clancey,
Thank you for your message!
I'm not sure if I understand your questions correctly regarding specialist materials. Could you explain?
General rule of thumb is that abrasive materials are not recommended, as they will wear down your nozzle. These are materials like carbon fiber, bronze / brass-fill and glow in the dark. If you want to remove any doubt, you should be in the safe zone with Ultimaker filaments for sure.
You can go for .8 print core if you want to save time and print fast. Because the nozzle is bigger, it can extrude more plastic, thus it can print thicker layers, and your print will be done faster.
This also means that generally, what people consider as quality (super smooth spheres) the quality is 'lower'. I mean the layers are thicker so it is easier to feel these steps with your finger nail. Detail in x and y is also less for the same reason, the nozzle is bigger. Like trying to make a detailed drawing with an Edding 800 marker.
Regarding the different print cores, you can choose different types of support constructions, and different support materials. One being support material which is the same material as your build, so a PP print has PP support and a Nylon print would have Nylon supports. You would remove them with pliers and potentially sand down your print to remove some final marks.
For this, you only need 1 print core. Everything will be built with an AA core.
With the Ultimaker 3 you can also print with 2 print cores (AA & BB). We have a special support material called PVA. PVA can be dissolved in water. This material is meant to be printed with the BB print core. This means your surfaces will be cleaner and you can print more complex parts since you no longer have to be able to reach everything with pliers.
Why should PVA be printed in the BB print core? PVA behaves differently when molten, and has a higher tendency to burn than other filaments. Therefore, the internal geometry of print core BB is different. It avoids the burning risk. This internal geometry makes it less fitting to use it for the build materials like PP, Nylon, PLA etc.
That is why there are 2 print cores, they are tailored to work best with different type of materials.
Let me know if you have any further questions!
Edited by GuestLink to post
