Hadn't thought of that ahoeben.
I don't know if glueing the two halves might create a thin layer of glue 'color' (different to the print's color) that will become visible when I cut into the lens post-processing.
Only one way to find out
I think by far the simplest method is like ahoeben says, but then you are going to have quite visible layer-steps, like stairs, especially in the center.
If you want less visible steps, maybe printing it vertical might be an option? But then you would need to design a sort of support beam structure around it, for good adhesion to the glass and for stability. If your printer has no Z-axis issues, this should give a smoother surface and require less post processing, I think. Of course the support needs to be cut off afterwards.
Would be interesting to compare both methods.
Edited by GuestI did not specify which axis to split the lens on. If you split the lens so you have a circle as the ground plane, then you are going to get fresnel-lens-like steps on the lens. But it you split the lens along the other orthogonal axis, you get a fairly smooth result (and a smaller contact area to smooth out after gluing)
Print it with Slic3r's Adaptive Layer Height to get a much smoother surface with greatly reduced stair-stepping.
Thank you all! I lost this post and only just found it again. Very useful info.
ahoeben 1,884
Split it down the middle and glue two parts together?
