Made a step-by-step guide for this: https://thopiekar.eu/cura/plugins/uninstallation/
That worked! Pretty explicit instruction on how to do it.
Drag-and-drop installer into cura and....
SUCCESS!
No idea on the quality issues yet, but the bug of not importing is either solved or making significant progress. Thanks!!!!
Print looks *very* round. Certainly better than 1*, but I suspect it's actually using mathematical curves instead of approximating it.
THIS. IS. AWESOME. I'd send you my life savings but it ain't worth the postage.
- 1
3 minutes ago, AbeFM said:That worked! Pretty explicit instruction on how to do it.
No problem. Tried to keep it short and informative as much as possible.
4 minutes ago, AbeFM said:No idea on the quality issues yet, but the bug of not importing is either solved or making significant progress. Thanks!!!!
Well, let me know whenever problems occur. Feedback is always welcome
Would you mind to tell me which SolidWorks version you are using?
Thanks!
6 minutes ago, AbeFM said:THIS. IS. AWESOME. I'd send you my life savings but it ain't worth the postage.
Haha, sounds like free beer for me
SW 2016 sp3 / win10 CURA 3.2.0
- 1
Having slicing issues due to stl's.
I had the same issue using the import macro as manually generating stl.
Any ideas? Maybe a post processing step is needed though it seems beyond the scope of this tool.
2 hours ago, AbeFM said:Any ideas? Maybe a post processing step is needed though it seems beyond the scope of this tool.
How do you mean? Is in your opinion the plugin also giving bad results? Or do you think it does it better compared to the manual STL export?
Thanks!
Could someone be so kind and convert the following file into STL and 3MF?
https://thopiekar.eu/download/_dev/CuraSolidWorksPluginTestCube.SLDPRT
Due to feedback from Ultimaker B.V. and people using SolidWorks 2017 and newer, there are issues with the plugin.
I need the files to fully understand what is going wrong.
At the moment I'm implementing a debug mode to the plugin, so it acts like any SolidWorks version is installed. So I can simulate the behaviour of the plugin on SolidWorks version, I even don't have.
Regards and enjoy your weekend!
Edited by thopiekarkmanstudios 1,120
20 minutes ago, thopiekar said:Could someone be so kind and convert the following file into STL and 3MF?
I feel for you dude.....good luck!!
@kmanstudios many thanks! I'm getting very close now. I guess it is a question of maximally an hour to get it done.
People, who know me good know that I'm not giving up too easily
kmanstudios 1,120
When I taught myself programming (I made some games using Yoyo games' Gamemaker) I would sometimes beat myself up on a problem for a day or two. Then I would move on to something else that had to be done for the game like graphics. Usually the solution would flash across my visual field with completed algorithms or bits of code. i am weird that way. I can hyperfocus until the world goes away and all I experience is what I am thinking of. Kinda not fun when it would happen in the middle of a college class lecture whilst writing on the whiteboard. Sigh...students would then snap me back after calling to me a few times saying I just froze and stopped talking. siggghhhh.....
So, I do understand and I still feel for you though
Well, people told me often in life that I can't do things because of XY and won't manage. I'm normally motivated by things I believe and am convinced about.
So whenever I hear those XY complains, then this is putting me on fire.
Btw. the debug mode works. Now I'm also able to see another bug, which I was not believing in.
However, I still need the files produced by SolidWorks. Because the 3MF file I have here, just works fine. I definitely need a 3MF file made by SolidWorks, which is crashing my plugin.
1 hour ago, thopiekar said:Could someone be so kind and convert the following file into STL and 3MF?
kmanstudios 1,120
7 minutes ago, thopiekar said:Well, people told me often in life that I can't do things because of XY and won't manage. I'm normally motivated by things I believe and am convinced about.
Right there widja boudreaux!
- 1
Got the files and here is the hero of the day: https://www.facebook.com/groups/2405941391/permalink/10156246755011392/
and best of all. I can reproduce the error. Drag an dropping his 3MF works, but using the function inside my plugin it fails.
Fixed! Never forget that 3MF SceneNodes have their children
A new testing version is up, soon.
On 19.10.2017 at 10:44 PM, thopiekar said:Latest version: CuraSolidWorksPlugin-0.5.3.curaplugin
New version released. Had to do many tweaks to the code after finding different issues.
* Confirmed to work on 2017: https://github.com/thopiekar/CuraSolidWorksPlugin/issues/48#issuecomment-366527143
Edited by thopiekarPut in 5.3 from the link above after deleting maco directory from CURA plugin folder.
First file always fails, subsequent files just hang, taking forever to "load", you can cancel them to try more. On restart it rejects the file as invalid again.
Win10,Cura3.2.0,Macro5.3 - drag-and-drop SW2013 file into Cura
Edited by AbeFM- 1
Hey @AbeFM,
thank you for testing the plugin.
7 hours ago, AbeFM said:Put in 5.3 from the link above after deleting maco directory from CURA plugin folder.
I'm unsure about what you wrote. Why did you remove the macro (?) directory? Or do you mean, that you removed the while plugin directory to uninstall it?
7 hours ago, AbeFM said:First file always fails, subsequent files just hang, taking forever to "load", you can cancel them to try more. On restart it rejects the file as invalid again.
Can you send me your log file?
Sorry, that the plugin does not work for you anymore whereas I managed to fix it for SWX 2017:
https://github.com/thopiekar/CuraSolidWorksPlugin/issues/48#issuecomment-366586668
PS: And it would be useful to reproduce the error by sending me the exported STL of the file you were trying to open.
Regards
Edited by thopiekarCertainly, and sorry for the slow response!
How do I "send you a log" - CURA's log, or your macro's? Where do I find said "log"? :-)
The files were any files I opened, the one posted earlier just as well - SLDPRT from SW2016 - the same files that worked with macro 0.5.1
Edited by AbeFM
Log file was 100+ MB, so I just took a few sections that had the word "solidworks" in them a lot. Hope it helps!
s skirt_brim_minimal_length="250" -s conical_overhang_angle="50" -s raft_smoothing="5" -s jerk_wall="20" -s wall_thickness="0.8" -s zig_zaggify_infill="True" -s ironing_pattern="zigzag" -s conical_overhang_enabled="False" -s ironing_only_highest_layer="False" -s meshfix="0" -s multiple_mesh_overlap="0.15" -s acceleration_travel="5000" -s raft_surface_jerk="20" -s support_z_distance="0.1" -s raft_speed="42.5" -s speed_infill="85" -s retraction_speed="25" -s wall_line_count="2" -s center_object="False" -s speed_support_bottom="56.666666666666664" -s material_initial_print_temperature="190" -s layer_start_y="0.0" -s mold_angle="40" -s speed_equalize_flow_enabled="False" -s skin_overlap_mm="0.02" -s jerk_support_infill="20" -s raft_interface_line_width="0.8" -s z_seam_y="636" -s support_use_towers="False" -s prime_tower_wipe_enabled="True" -s support_interface_density="100" -s mesh_position_z="0" -s brim_outside_only="True" -e0 -l "0" 2018-02-20 09:09:59,876 - DEBUG - [(2388)-Thread-17] UM.Backend.Backend._backendLog [90]: [Backend] [WARNING] There are empty layers (or layers with empty extruder plans) in the print! Temperature control and cross layer travel moves might suffer. 2018-02-20 09:10:00,793 - DEBUG - [(17364)-MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [582]: Slicing took 5.789367437362671 seconds 2018-02-20 09:10:00,794 - DEBUG - [(17364)-MainThread] CuraEngineBackend.CuraEngineBackend._onSlicingFinishedMessage [591]: See if there is more to slice... 2018-02-20 09:10:00,794 - DEBUG - [(6840)-Thread-4] CuraEngineBackend.ProcessSlicedLayersJob.run [70]: Processing new layer for build plate 0... 2018-02-20 09:10:00,852 - DEBUG - [(17364)-MainThread] UM.Backend.Backend._logSocketState [181]: Socket state changed to Closing 2018-02-20 09:10:00,857 - DEBUG - [(17364)-MainThread] UM.Backend.Backend._onSocketError [203]: Socket debug: Arcus Error (13): Closing socket because other side requested close. 2018-02-20 09:10:00,861 - DEBUG - [(17364)-MainThread] UM.Backend.Backend._logSocketState [183]: Socket state changed to Closed 2018-02-20 09:10:00,864 - DEBUG - [(17364)-MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [722]: Backend quit with return code 0. Resetting process and socket. 2018-02-20 09:10:01,163 - DEBUG - [(6840)-Thread-4] CuraEngineBackend.ProcessSlicedLayersJob.run [236]: Processing layers took 0.3682224750518799 seconds 2018-02-20 09:10:01,200 - DEBUG - [(17364)-MainThread] CuraEngineBackend.CuraEngineBackend._onProcessLayersFinished [750]: See if there is more to slice(2)... 2018-02-20 09:11:11,925 - DEBUG - [(17364)-MainThread] RemovableDriveOutputDevice.RemovableDriveOutputDevice.requestWrite [81]: Writing to G:/4_GelMold1.gcode 2018-02-20 09:11:12,020 - INFO - [(15972)-Thread-5] SliceInfoPlugin.SliceInfoJob.run [29]: Sending anonymous slice info to [https://stats.ultimaker.com/api/cura]... 2018-02-20 09:11:12,150 - WARNING - [(8380)-Thread-6] GCodeWriter.GCodeWriter._serialiseSettings [129]: No extruder quality profile found, not writing quality for extruder custom_extruder_2 #3 to file! 2018-02-20 09:11:12,151 - WARNING - [(8380)-Thread-6] GCodeWriter.GCodeWriter._serialiseSettings [129]: No extruder quality profile found, not writing quality for extruder custom_extruder_3 #3 to file! 2018-02-20 09:11:12,153 - WARNING - [(8380)-Thread-6] GCodeWriter.GCodeWriter._serialiseSettings [129]: No extruder quality profile found, not writing quality for extruder custom_extruder_4 #3 to file! 2018-02-20 09:11:12,154 - WARNING - [(8380)-Thread-6] GCodeWriter.GCodeWriter._serialiseSettings [129]: No extruder quality profile found, not writing quality for extruder custom_extruder_5 #3 to file! 2018-02-20 09:11:12,156 - WARNING - [(8380)-Thread-6] GCodeWriter.GCodeWriter._serialiseSettings [129]: No extruder quality profile found, not writing quality for extruder custom_extruder_6 #3 to file! 2018-02-20 09:11:12,158 - WARNING - [(8380)-Thread-6] GCodeWriter.GCodeWriter._serialiseSettings [129]: No extruder quality profile found, not writing quality for extruder custom_extruder_7 #3 to file! 2018-02-20 09:11:12,160 - WARNING - [(8380)-Thread-6] GCodeWriter.GCodeWriter._serialiseSettings [129]: No extruder quality profile found, not writing quality for extruder custom_extruder_8 #3 to file! 2018-02-20 09:11:12,162 - DEBUG - [(8380)-Thread-6] UM.FileHandler.WriteFileJob.run [61]: Writing file took 0.14137554168701172 seconds 2018-02-20 09:11:12,859 - INFO - [(15972)-Thread-5] SliceInfoPlugin.SliceInfoJob.run [33]: Sent anonymous slice info. 2018-02-20 09:11:15,232 - INFO - [(17364)-MainThread] RemovableDriveOutputDevice.RemovableDrivePlugin.ejectDevice [44]: Attempting to eject the device 2018-02-20 09:11:15,293 - INFO - [(17364)-MainThread] RemovableDriveOutputDevice.RemovableDrivePlugin.ejectDevice [51]: Succesfully ejected the device 2018-02-20 16:29:35,755 - DEBUG - [(17364)-MainThread] UM.View.GL.ShaderProgram.load [55]: Loading shader file [C:\Program Files\Ultimaker Cura 3.2\resources\shaders\toolhandle.shader]... 2018-02-20 16:29:36,643 - WARNING - [(17364)-MainThread] UM.Qt.QtApplication.__onQmlWarning [267]: file:///C:/Program Files/Ultimaker Cura 3.2/qml/QtQuick/Controls/TextField.qml:638:5: QML TextInputWithHandles: Binding loop detected for property "text" 2018-02-20 16:29:48,879 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.preRead [328]: Showing wizard, if needed.. 2018-02-20 16:29:48,885 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksDialogHandler.showConfigUI [118]: Showing wizard is not needed.. (preference = True) 2018-02-20 16:29:48,885 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksDialogHandler.showConfigUI [126]: Waiting for UI to close.. 2018-02-20 16:29:48,887 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksDialogHandler.waitForUIToClose [108]: Waitiung for UI to close.. 2018-02-20 16:29:56,000 - DEBUG - [(17364)-MainThread] CuraSolidWorksPlugin.SolidWorksDialogHandler.onOkButtonClicked [136]: Clicked on OkButton 2018-02-20 16:29:56,016 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksDialogHandler.waitForUIToClose [110]: Got lock and releasing it now.. 2018-02-20 16:29:56,017 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksDialogHandler.waitForUIToClose [112]: Lock released! 2018-02-20 16:29:56,017 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.preRead [333]: Continuing to convert file.. 2018-02-20 16:29:56,018 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [25]: Calling SldWorks.Application.24... 2018-02-20 16:29:56,019 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [27]: CreateActiveObject.. 2018-02-20 16:29:56,076 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [366]: Mayor version is: 24 2018-02-20 16:29:56,076 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [367]: Minor version is: 3 2018-02-20 16:29:56,077 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [368]: Patch version is: 0 2018-02-20 16:29:56,077 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.getFriendlyName [103]: revision_major is: 24 2018-02-20 16:29:56,077 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.startApp [417]: Started: SolidWorks 2016 2018-02-20 16:29:56,083 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [140]: ... and opening file. 2018-02-20 16:29:56,087 - INFO - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.getOpenDocuments [479]: Found 1 open files.. 2018-02-20 16:29:56,090 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.openForeignFile [586]: Foreign file has already been opened! 2018-02-20 16:29:56,092 - INFO - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.getOpenDocuments [479]: Found 1 open files.. 2018-02-20 16:29:56,117 - INFO - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [144]: Trying to convert into one of: ['stl'] 2018-02-20 16:29:56,117 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [146]: Trying to convert <LogMomSpcr.SLDPRT>... 2018-02-20 16:29:56,117 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [151]: Using suggested tempdir: 'C:\\Users\\Abe\\AppData\\Local\\Temp' 2018-02-20 16:29:56,118 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [157]: ... into 'stl' format: <C:\Users\Abe\AppData\Local\Temp\04ae3517-3388-4673-985c-46192a584935.STL> 2018-02-20 16:29:56,137 - INFO - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.exportFileAs [699]: Using fine quality for 3D printing! 2018-02-20 16:29:56,512 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [182]: Found temporary file! (size: 2.9011573791503906MB) 2018-02-20 16:29:56,514 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [207]: Using reader: STLReader 2018-02-20 16:29:56,537 - DEBUG - [(1444)-Thread-7] UM.Mesh.MeshData.calculateNormalsFromVertices [421]: Calculating normals took 0.008019685745239258 seconds 2018-02-20 16:29:56,541 - DEBUG - [(1444)-Thread-7] STLReader.STLReader.read [79]: Loaded a mesh with 182520 vertices 2018-02-20 16:29:56,543 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonReader.readOnSingleAppLayer [219]: Removing temporary stl file, called <C:\Users\Abe\AppData\Local\Temp\04ae3517-3388-4673-985c-46192a584935.STL> 2018-02-20 16:29:56,544 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.closeApp [424]: Rolling back changes on app_frame. 2018-02-20 16:29:56,622 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.closeApp [431]: Rolling back changes on app_instance. 2018-02-20 16:29:56,623 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.closeApp [441]: Closed SolidWorks. 2018-02-20 16:29:56,625 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.postCloseApp [71]: postCloseApp.. 2018-02-20 16:29:56,625 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.SolidWorksReader.nodePostProcessing [762]: Doing postprocessing on: [<UM.Scene.SceneNode.SceneNode object at 0x0000025B81CE3B70>] 2018-02-20 16:29:56,625 - DEBUG - [(1444)-Thread-7] CuraSolidWorksPlugin.CadIntegrationUtils.CommonReader.renameNodes [106]: File path in mesh was: C:\Users\Abe\AppData\Local\Temp\04ae3517-3388-4673-985c-46192a584935.STL 2018-02-20 16:29:56,628 - ERROR - [(1444)-Thread-7] UM.Logger.logException [82]: Exception: Exception occurred while loading file C:/Users/Abe/Google Drive/3D_Printing/Objects/~AbeStuff/LogMomSpcr.SLDPRT 2018-02-20 16:29:56,631 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-20 16:29:56,632 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: File "X:\3.2\build\inst\lib\python3.5\site-packages\UM\FileHandler\ReadFileJob.py", line 66, in run 2018-02-20 16:29:56,633 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: File "X:\3.2\build\inst\lib\python3.5\site-packages\UM\Mesh\MeshFileHandler.py", line 28, in readerRead 2018-02-20 16:29:56,635 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\CommonComReader.py", line 79, in read 2018-02-20 16:29:56,637 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: result = self.readOnMultipleAppLayer(options) 2018-02-20 16:29:56,638 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\CommonReader.py", line 277, in readOnMultipleAppLayer 2018-02-20 16:29:56,640 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: self.nodePostProcessing(options, scene_node_list) 2018-02-20 16:29:56,641 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\SolidWorksReader.py", line 767, in nodePostProcessing 2018-02-20 16:29:56,643 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: revision = self.getRevisionNumber(options) 2018-02-20 16:29:56,644 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\SolidWorksReader.py", line 362, in getRevisionNumber 2018-02-20 16:29:56,645 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: revision_number = options["app_instance"].RevisionNumber 2018-02-20 16:29:56,647 - ERROR - [(1444)-Thread-7] UM.Logger.logException [86]: KeyError: 'app_instance' 2018-02-20 16:29:56,882 - DEBUG - [(17364)-MainThread] UM.Mesh.MeshData.approximateConvexHull [388]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.3399028778076172 seconds. 16560 input vertices. 16560 output vertices. 2018-02-20 16:29:56,900 - WARNING - [(17364)-MainThread] UM.Qt.QtApplication.__onQmlWarning [267]: file:///C:/Program Files/Ultimaker Cura 3.2/qml/QtQuick/Controls/TextField.qml:638:5: QML TextInputWithHandles: Binding loop detected for property "text" 2018-02-20 16:30:05,137 - DEBUG - [(17364)-MainThread] UM.Qt.QtApplication.windowClosed [345]: Shutting down cura 2018-02-20 16:30:05,346 - DEBUG - [(17364)-MainThread] CuraEngineBackend.CuraEngineBackend._terminate [262]: Attempting to kill the engine process 2018-02-20 16:30:59,416 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin FileLogger 2018-02-20 16:30:59,536 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin FirmwareUpdateChecker 2018-02-20 16:30:59,557 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeProfileReader 2018-02-20 16:30:59,599 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeReader 2018-02-20 16:30:59,617 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeWriter 2018-02-20 16:30:59,647 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ImageReader 2018-02-20 16:30:59,670 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LegacyProfileReader 2018-02-20 16:30:59,696 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LocalContainerProvider 2018-02-20 16:30:59,732 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LocalFileOutputDevice 2018-02-20 16:30:59,756 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MachineSettingsAction 2018-02-20 16:30:59,777 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MonitorStage 2018-02-20 16:30:59,808 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PerObjectSettingsTool 2018-02-20 16:30:59,831 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PluginBrowser 2018-02-20 16:30:59,853 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PostProcessingPlugin 2018-02-20 16:30:59,874 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PrepareStage 2018-02-20 16:30:59,909 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin RemovableDriveOutputDevice 2018-02-20 16:30:59,971 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SimulationView 2018-02-20 16:31:00,003 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SliceInfoPlugin 2018-02-20 16:31:00,026 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SolidView 2018-02-20 16:31:00,050 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin CameraTool 2018-02-20 16:31:00,077 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MirrorTool 2018-02-20 16:31:00,106 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin RotateTool 2018-02-20 16:31:00,139 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ScaleTool 2018-02-20 16:31:00,161 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SelectionTool 2018-02-20 16:31:00,192 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin TranslateTool 2018-02-20 16:31:00,247 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UltimakerMachineActions 2018-02-20 16:31:00,353 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UM3NetworkPrinting 2018-02-20 16:31:00,385 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UpdateChecker 2018-02-20 16:31:00,386 - INFO - [(756)-Thread-3] UpdateChecker.UpdateCheckerJob.run [34]: Checking for new version of cura 2018-02-20 16:31:00,460 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin USBPrinting 2018-02-20 16:31:00,479 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UserAgreementPlugin 2018-02-20 16:31:00,522 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade21to22 2018-02-20 16:31:00,545 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade22to24 2018-02-20 16:31:00,569 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade25to26 2018-02-20 16:31:00,593 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade26to27 2018-02-20 16:31:00,614 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade27to30 2018-02-20 16:31:00,641 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade30to31 2018-02-20 16:31:00,664 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SimpleView 2018-02-20 16:31:00,694 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin X3DReader 2018-02-20 16:31:00,734 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin XmlMaterialProfile 2018-02-20 16:31:00,763 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin XRayView 2018-02-20 16:31:00,781 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin BarbarianPlugin 2018-02-20 16:31:00,819 - INFO - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [11]: Python version: sys.version_info(major=3, minor=5, micro=2, releaselevel='final', serial=0) 2018-02-20 16:31:00,820 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [14]: Found 3rd-party directory and adding in into PYTHONPATH. 2018-02-20 16:31:00,821 - INFO - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [18]: Looking for win32com in Cura.. 2018-02-20 16:31:00,827 - INFO - [(756)-Thread-3] UpdateChecker.UpdateCheckerJob.run [70]: Found a new version of the software. Spawning message 2018-02-20 16:31:00,833 - INFO - [(16756)-MainThread] UM.Logger.logException [82]: Exception: .. Probably couldn't find it. Using our own.. 2018-02-20 16:31:00,843 - INFO - [(16756)-MainThread] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-20 16:31:00,845 - INFO - [(16756)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\__init__.py", line 19, in <module> 2018-02-20 16:31:00,848 - INFO - [(16756)-MainThread] UM.Logger.logException [86]: import win32com 2018-02-20 16:31:00,850 - INFO - [(16756)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\..\3rd-party\win32com\__init__.py", line 5, in <module> 2018-02-20 16:31:00,852 - INFO - [(16756)-MainThread] UM.Logger.logException [86]: import win32api, sys, os 2018-02-20 16:31:00,854 - INFO - [(16756)-MainThread] UM.Logger.logException [86]: ImportError: No module named 'win32api' 2018-02-20 16:31:00,854 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [46]: sys.path: ['C:\\Program Files\\Ultimaker Cura 3.2', 'C:\\Program Files\\Ultimaker Cura 3.2\\python35.zip', 'C:\\Program Files\\Ultimaker Cura 3.2\\DLLs', 'C:\\Program Files\\Ultimaker Cura 3.2\\lib', 'C:\\Program Files\\Ultimaker Cura 3.2', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\ComFactory\\..\\3rd-party', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\pythonwin', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\win32', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\win32\\lib', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\pywin32_system32'] 2018-02-20 16:31:00,994 - INFO - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [51]: ComFactory: Using pywin32! 2018-02-20 16:31:01,045 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [25]: Calling SldWorks.Application.24... 2018-02-20 16:31:01,045 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [27]: CreateActiveObject.. 2018-02-20 16:31:01,050 - DEBUG - [(16756)-MainThread] UM.Logger.logException [82]: Exception: Getting active object without Coinit failed 2018-02-20 16:31:01,065 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-20 16:31:01,067 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\CommonComReader.py", line 31, in startApp 2018-02-20 16:31:01,070 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: options["app_instance"] = ComConnector.CreateActiveObject(options["app_name"]) 2018-02-20 16:31:01,072 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\PyWin32Connector.py", line 22, in CreateActiveObject 2018-02-20 16:31:01,074 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: return win32com.client.GetActiveObject(app_name) 2018-02-20 16:31:01,076 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\..\3rd-party\win32com\client\__init__.py", line 79, in GetActiveObject 2018-02-20 16:31:01,077 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: dispatch = pythoncom.GetActiveObject(resultCLSID) 2018-02-20 16:31:01,079 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: pywintypes.com_error: (-2147221021, 'Operation unavailable', None, None) 2018-02-20 16:31:01,079 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [37]: CoInit.. 2018-02-20 16:31:01,081 - DEBUG - [(16756)-MainThread] UM.Logger.logException [82]: Exception: Getting active object with Coinit failed 2018-02-20 16:31:01,083 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-20 16:31:01,085 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\CommonComReader.py", line 38, in startApp 2018-02-20 16:31:01,086 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: ComConnector.CoInit() 2018-02-20 16:31:01,087 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\PyWin32Connector.py", line 25, in CoInit 2018-02-20 16:31:01,088 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: pythoncom.CoInitializeEx(pythoncom.COINIT_MULTITHREADED) 2018-02-20 16:31:01,090 - DEBUG - [(16756)-MainThread] UM.Logger.logException [86]: pywintypes.com_error: (-2147417850, 'Cannot change thread mode after it is set.', None, None) 2018-02-20 16:31:01,091 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [49]: Trying to get new class object.. 2018-02-20 16:31:01,111 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [366]: Mayor version is: 24 2018-02-20 16:31:01,112 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [367]: Minor version is: 3 2018-02-20 16:31:01,112 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [368]: Patch version is: 0 2018-02-20 16:31:01,113 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getFriendlyName [103]: revision_major is: 24 2018-02-20 16:31:01,113 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.startApp [417]: Started: SolidWorks 2016 2018-02-20 16:31:01,114 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [366]: Mayor version is: 24 2018-02-20 16:31:01,115 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [367]: Minor version is: 3 2018-02-20 16:31:01,115 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [368]: Patch version is: 0 2018-02-20 16:31:01,118 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.closeApp [424]: Rolling back changes on app_frame. 2018-02-20 16:31:01,119 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.closeApp [431]: Rolling back changes on app_instance. 2018-02-20 16:31:01,120 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.closeApp [441]: Closed SolidWorks. 2018-02-20 16:31:01,120 - INFO - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getOpenDocuments [479]: Found 0 open files.. 2018-02-20 16:31:01,121 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.checkForBasicFunctions [239]: Looks like we opened SolidWorks and there are no open files. Let's close SolidWorks again! 2018-02-20 16:31:01,122 - DEBUG - [(16756)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.postCloseApp [71]: postCloseApp.. 2018-02-20 16:31:01,122 - INFO - [(16756)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.isVersionOperational [298]: Success! Installation of 'SldWorks.Application.24' seems to be valid! 2018-02-20 16:31:01,427 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin CuraSolidWorksPlugin 2018-02-20 16:31:01,526 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin OrientationPlugin 2018-02-20 16:31:01,554 - INFO - [(16756)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ZOffsetPlugin 2018-02-20 16:31:01,571 - INFO - [(16756)-MainThread] UM.VersionUpgradeManager.upgrade [113]: Looking for old configuration files to upgrade. 2018-02-20 16:31:02,993 - DEBUG - [(16756)-MainThread] UM.Backend.Backend._logSocketState [173]: Socket state changed to Listening 2018-02-20 16:31:03,044 - INFO - [(16756)-MainThread] UM.Backend.Backend.startEngine [74]: Started engine process: C:\Program Files\Ultimaker Cura 3.2\CuraEngine.exe 2018-02-20 16:31:03,047 - DEBUG - [(16756)-MainThread] UM.Backend.Backend._backendLog [90]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 3.2\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\\Program Files\\Ultimaker Cura 3.2\\resources\\definitions\\fdmprinter.def.json', ''] 2018-02-20 16:31:03,167 - DEBUG - [(15816)-Thread-14] UM.Backend.Backend._backendLog [90]: [Backend] 2018-02-20 16:31:03,169 - DEBUG - [(15816)-Thread-14] UM.Backend.Backend._backendLog [90]: [Backend] Cura_SteamEngine version DEV 2018-02-20 16:31:03,170 - DEBUG - [(15816)-Thread-14] UM.Backend.Backend._backendLog [90]: [Backend] Copyright (C) 2017 Ultimaker 2018-02-20 16:31:03,175 - DEBUG - [(15816)-Thread-14] UM.Backend.Backend._backendLog [90]: [Backend] 2018-02-20 16:31:03,176 - DEBUG - [(16756)-MainThread] UM.Backend.Backend._logSocketState [177]: Socket state changed to Connected 2018-02-20 TRIMMED 2018-02-21 13:59:48,222 - DEBUG - [(16756)-MainThread] CuraEngineBackend.CuraEngineBackend._terminate [262]: Attempting to kill the engine process 2018-02-21 14:21:29,303 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin FileLogger 2018-02-21 14:21:29,416 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin FirmwareUpdateChecker 2018-02-21 14:21:29,434 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeProfileReader 2018-02-21 14:21:29,480 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeReader 2018-02-21 14:21:29,499 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeWriter 2018-02-21 14:21:29,528 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ImageReader 2018-02-21 14:21:29,546 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LegacyProfileReader 2018-02-21 14:21:29,566 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LocalContainerProvider 2018-02-21 14:21:29,592 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LocalFileOutputDevice 2018-02-21 14:21:29,614 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MachineSettingsAction 2018-02-21 14:21:29,634 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MonitorStage 2018-02-21 14:21:29,663 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PerObjectSettingsTool 2018-02-21 14:21:29,684 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PluginBrowser 2018-02-21 14:21:29,706 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PostProcessingPlugin 2018-02-21 14:21:29,725 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PrepareStage 2018-02-21 14:21:29,756 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin RemovableDriveOutputDevice 2018-02-21 14:21:29,803 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SimulationView 2018-02-21 14:21:29,829 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SliceInfoPlugin 2018-02-21 14:21:29,851 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SolidView 2018-02-21 14:21:29,875 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin CameraTool 2018-02-21 14:21:29,904 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MirrorTool 2018-02-21 14:21:29,937 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin RotateTool 2018-02-21 14:21:29,968 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ScaleTool 2018-02-21 14:21:29,990 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SelectionTool 2018-02-21 14:21:30,019 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin TranslateTool 2018-02-21 14:21:30,066 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UltimakerMachineActions 2018-02-21 14:21:30,171 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UM3NetworkPrinting 2018-02-21 14:21:30,203 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UpdateChecker 2018-02-21 14:21:30,206 - INFO - [(18260)-Thread-3] UpdateChecker.UpdateCheckerJob.run [34]: Checking for new version of cura 2018-02-21 14:21:30,285 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin USBPrinting 2018-02-21 14:21:30,308 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UserAgreementPlugin 2018-02-21 14:21:30,352 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade21to22 2018-02-21 14:21:30,377 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade22to24 2018-02-21 14:21:30,402 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade25to26 2018-02-21 14:21:30,427 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade26to27 2018-02-21 14:21:30,451 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade27to30 2018-02-21 14:21:30,480 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade30to31 2018-02-21 14:21:30,505 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SimpleView 2018-02-21 14:21:30,537 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin X3DReader 2018-02-21 14:21:30,574 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin XmlMaterialProfile 2018-02-21 14:21:30,595 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin XRayView 2018-02-21 14:21:30,617 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin BarbarianPlugin 2018-02-21 14:21:30,646 - INFO - [(18260)-Thread-3] UpdateChecker.UpdateCheckerJob.run [70]: Found a new version of the software. Spawning message 2018-02-21 14:21:30,651 - INFO - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [11]: Python version: sys.version_info(major=3, minor=5, micro=2, releaselevel='final', serial=0) 2018-02-21 14:21:30,651 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [14]: Found 3rd-party directory and adding in into PYTHONPATH. 2018-02-21 14:21:30,651 - INFO - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [18]: Looking for win32com in Cura.. 2018-02-21 14:21:30,658 - INFO - [(2220)-MainThread] UM.Logger.logException [82]: Exception: .. Probably couldn't find it. Using our own.. 2018-02-21 14:21:30,662 - INFO - [(2220)-MainThread] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-21 14:21:30,663 - INFO - [(2220)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\__init__.py", line 19, in <module> 2018-02-21 14:21:30,664 - INFO - [(2220)-MainThread] UM.Logger.logException [86]: import win32com 2018-02-21 14:21:30,666 - INFO - [(2220)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\..\3rd-party\win32com\__init__.py", line 5, in <module> 2018-02-21 14:21:30,669 - INFO - [(2220)-MainThread] UM.Logger.logException [86]: import win32api, sys, os 2018-02-21 14:21:30,671 - INFO - [(2220)-MainThread] UM.Logger.logException [86]: ImportError: No module named 'win32api' 2018-02-21 14:21:30,672 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [46]: sys.path: ['C:\\Program Files\\Ultimaker Cura 3.2', 'C:\\Program Files\\Ultimaker Cura 3.2\\python35.zip', 'C:\\Program Files\\Ultimaker Cura 3.2\\DLLs', 'C:\\Program Files\\Ultimaker Cura 3.2\\lib', 'C:\\Program Files\\Ultimaker Cura 3.2', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\ComFactory\\..\\3rd-party', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\pythonwin', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\win32', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\win32\\lib', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\pywin32_system32'] 2018-02-21 14:21:30,754 - INFO - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [51]: ComFactory: Using pywin32! 2018-02-21 14:21:30,808 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [25]: Calling SldWorks.Application.24... 2018-02-21 14:21:30,808 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [27]: CreateActiveObject.. 2018-02-21 14:21:30,811 - DEBUG - [(2220)-MainThread] UM.Logger.logException [82]: Exception: Getting active object without Coinit failed 2018-02-21 14:21:30,821 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-21 14:21:30,822 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\CommonComReader.py", line 31, in startApp 2018-02-21 14:21:30,823 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: options["app_instance"] = ComConnector.CreateActiveObject(options["app_name"]) 2018-02-21 14:21:30,825 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\PyWin32Connector.py", line 22, in CreateActiveObject 2018-02-21 14:21:30,826 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: return win32com.client.GetActiveObject(app_name) 2018-02-21 14:21:30,827 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\..\3rd-party\win32com\client\__init__.py", line 79, in GetActiveObject 2018-02-21 14:21:30,828 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: dispatch = pythoncom.GetActiveObject(resultCLSID) 2018-02-21 14:21:30,830 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: pywintypes.com_error: (-2147221021, 'Operation unavailable', None, None) 2018-02-21 14:21:30,830 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [37]: CoInit.. 2018-02-21 14:21:30,832 - DEBUG - [(2220)-MainThread] UM.Logger.logException [82]: Exception: Getting active object with Coinit failed 2018-02-21 14:21:30,834 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-21 14:21:30,835 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\CommonComReader.py", line 38, in startApp 2018-02-21 14:21:30,837 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: ComConnector.CoInit() 2018-02-21 14:21:30,838 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\PyWin32Connector.py", line 25, in CoInit 2018-02-21 14:21:30,840 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: pythoncom.CoInitializeEx(pythoncom.COINIT_MULTITHREADED) 2018-02-21 14:21:30,842 - DEBUG - [(2220)-MainThread] UM.Logger.logException [86]: pywintypes.com_error: (-2147417850, 'Cannot change thread mode after it is set.', None, None) 2018-02-21 14:21:30,842 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [49]: Trying to get new class object.. 2018-02-21 14:21:38,202 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [366]: Mayor version is: 24 2018-02-21 14:21:38,203 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [367]: Minor version is: 3 2018-02-21 14:21:38,203 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [368]: Patch version is: 0 2018-02-21 14:21:38,204 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getFriendlyName [103]: revision_major is: 24 2018-02-21 14:21:38,204 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.startApp [417]: Started: SolidWorks 2016 2018-02-21 14:21:38,240 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [366]: Mayor version is: 24 2018-02-21 14:21:38,240 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [367]: Minor version is: 3 2018-02-21 14:21:38,240 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [368]: Patch version is: 0 2018-02-21 14:21:38,305 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.closeApp [424]: Rolling back changes on app_frame. 2018-02-21 14:21:38,306 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.closeApp [431]: Rolling back changes on app_instance. 2018-02-21 14:21:38,309 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.closeApp [441]: Closed SolidWorks. 2018-02-21 14:21:38,310 - INFO - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getOpenDocuments [479]: Found 0 open files.. 2018-02-21 14:21:38,311 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.checkForBasicFunctions [239]: Looks like we opened SolidWorks and there are no open files. Let's close SolidWorks again! 2018-02-21 14:21:38,313 - DEBUG - [(2220)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.postCloseApp [71]: postCloseApp.. 2018-02-21 14:21:38,314 - INFO - [(2220)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.isVersionOperational [298]: Success! Installation of 'SldWorks.Application.24' seems to be valid! 2018-02-21 14:21:39,761 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin CuraSolidWorksPlugin 2018-02-21 14:21:39,884 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin OrientationPlugin 2018-02-21 14:21:39,909 - INFO - [(2220)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ZOffsetPlugin 2018-02-21 14:21:39,933 - INFO - [(2220)-MainThread] UM.VersionUpgradeManager.upgrade [113]: Looking for old configuration files to upgrade. 2018-02-21 14:21:41,446 - DEBUG - [(2220)-MainThread] UM.Backend.Backend._logSocketState [173]: Socket state changed to Listening 2018-02-21 14:21:41,509 - INFO - [(2220)-MainThread] UM.Backend.Backend.startEngine [74]: Started engine process: C:\Program Files\Ultimaker Cura 3.2\CuraEngine.exe 2018-02-21 14:21:41,516 - DEBUG - [(2220)-MainThread] UM.Backend.Backend._backendLog [90]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 3.2\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\\Program Files\\Ultimaker Cura 3.2\\resources\\definitions\\fdmprinter.def.json', ''] 2018-02-21 14:21:41,645 - DEBUG - [(17120)-Thread-14] UM.Backend.Backend._backen TRIMMED! 2018-02-21 14:22:04,806 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin FileLogger 2018-02-21 14:22:04,851 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin FirmwareUpdateChecker 2018-02-21 14:22:04,858 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeProfileReader 2018-02-21 14:22:04,876 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeReader 2018-02-21 14:22:04,883 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin GCodeWriter 2018-02-21 14:22:04,892 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ImageReader 2018-02-21 14:22:04,901 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LegacyProfileReader 2018-02-21 14:22:04,909 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LocalContainerProvider 2018-02-21 14:22:04,920 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin LocalFileOutputDevice 2018-02-21 14:22:04,931 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MachineSettingsAction 2018-02-21 14:22:04,938 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MonitorStage 2018-02-21 14:22:04,951 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PerObjectSettingsTool 2018-02-21 14:22:04,962 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PluginBrowser 2018-02-21 14:22:04,972 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PostProcessingPlugin 2018-02-21 14:22:04,980 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin PrepareStage 2018-02-21 14:22:04,993 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin RemovableDriveOutputDevice 2018-02-21 14:22:05,014 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SimulationView 2018-02-21 14:22:05,026 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SliceInfoPlugin 2018-02-21 14:22:05,034 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SolidView 2018-02-21 14:22:05,044 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin CameraTool 2018-02-21 14:22:05,056 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin MirrorTool 2018-02-21 14:22:05,068 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin RotateTool 2018-02-21 14:22:05,082 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ScaleTool 2018-02-21 14:22:05,091 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SelectionTool 2018-02-21 14:22:05,104 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin TranslateTool 2018-02-21 14:22:05,121 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UltimakerMachineActions 2018-02-21 14:22:05,189 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UM3NetworkPrinting 2018-02-21 14:22:05,204 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UpdateChecker 2018-02-21 14:22:05,206 - INFO - [(16052)-Thread-3] UpdateChecker.UpdateCheckerJob.run [34]: Checking for new version of cura 2018-02-21 14:22:05,237 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin USBPrinting 2018-02-21 14:22:05,245 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin UserAgreementPlugin 2018-02-21 14:22:05,259 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade21to22 2018-02-21 14:22:05,269 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade22to24 2018-02-21 14:22:05,280 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade25to26 2018-02-21 14:22:05,290 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade26to27 2018-02-21 14:22:05,299 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade27to30 2018-02-21 14:22:05,309 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin VersionUpgrade30to31 2018-02-21 14:22:05,318 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin SimpleView 2018-02-21 14:22:05,336 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin X3DReader 2018-02-21 14:22:05,353 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin XmlMaterialProfile 2018-02-21 14:22:05,363 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin XRayView 2018-02-21 14:22:05,371 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin BarbarianPlugin 2018-02-21 14:22:05,378 - INFO - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [11]: Python version: sys.version_info(major=3, minor=5, micro=2, releaselevel='final', serial=0) 2018-02-21 14:22:05,378 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [14]: Found 3rd-party directory and adding in into PYTHONPATH. 2018-02-21 14:22:05,379 - INFO - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [18]: Looking for win32com in Cura.. 2018-02-21 14:22:05,382 - INFO - [(1488)-MainThread] UM.Logger.logException [82]: Exception: .. Probably couldn't find it. Using our own.. 2018-02-21 14:22:05,385 - INFO - [(1488)-MainThread] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-21 14:22:05,386 - INFO - [(1488)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\__init__.py", line 19, in <module> 2018-02-21 14:22:05,388 - INFO - [(1488)-MainThread] UM.Logger.logException [86]: import win32com 2018-02-21 14:22:05,389 - INFO - [(1488)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\..\3rd-party\win32com\__init__.py", line 5, in <module> 2018-02-21 14:22:05,391 - INFO - [(1488)-MainThread] UM.Logger.logException [86]: import win32api, sys, os 2018-02-21 14:22:05,393 - INFO - [(1488)-MainThread] UM.Logger.logException [86]: ImportError: No module named 'win32api' 2018-02-21 14:22:05,393 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [46]: sys.path: ['C:\\Program Files\\Ultimaker Cura 3.2', 'C:\\Program Files\\Ultimaker Cura 3.2\\python35.zip', 'C:\\Program Files\\Ultimaker Cura 3.2\\DLLs', 'C:\\Program Files\\Ultimaker Cura 3.2\\lib', 'C:\\Program Files\\Ultimaker Cura 3.2', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\ComFactory\\..\\3rd-party', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\pythonwin', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\win32', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\win32\\lib', 'C:\\Users\\Abe\\AppData\\Roaming\\cura\\3.2\\plugins\\CuraSolidWorksPlugin\\CuraSolidWorksPlugin\\CadIntegrationUtils\\3rd-party\\pywin32_system32'] 2018-02-21 14:22:05,410 - INFO - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.ComFactory.<module> [51]: ComFactory: Using pywin32! 2018-02-21 14:22:05,430 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [25]: Calling SldWorks.Application.24... 2018-02-21 14:22:05,430 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [27]: CreateActiveObject.. 2018-02-21 14:22:05,433 - DEBUG - [(1488)-MainThread] UM.Logger.logException [82]: Exception: Getting active object without Coinit failed 2018-02-21 14:22:05,436 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-21 14:22:05,438 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\CommonComReader.py", line 31, in startApp 2018-02-21 14:22:05,439 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: options["app_instance"] = ComConnector.CreateActiveObject(options["app_name"]) 2018-02-21 14:22:05,440 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\PyWin32Connector.py", line 22, in CreateActiveObject 2018-02-21 14:22:05,441 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: return win32com.client.GetActiveObject(app_name) 2018-02-21 14:22:05,443 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\..\3rd-party\win32com\client\__init__.py", line 79, in GetActiveObject 2018-02-21 14:22:05,444 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: dispatch = pythoncom.GetActiveObject(resultCLSID) 2018-02-21 14:22:05,445 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: pywintypes.com_error: (-2147221021, 'Operation unavailable', None, None) 2018-02-21 14:22:05,445 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [37]: CoInit.. 2018-02-21 14:22:05,447 - DEBUG - [(1488)-MainThread] UM.Logger.logException [82]: Exception: Getting active object with Coinit failed 2018-02-21 14:22:05,449 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: Traceback (most recent call last): 2018-02-21 14:22:05,450 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\CommonComReader.py", line 38, in startApp 2018-02-21 14:22:05,453 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: ComConnector.CoInit() 2018-02-21 14:22:05,454 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: File "C:\Users\Abe\AppData\Roaming\cura\3.2\plugins\CuraSolidWorksPlugin\CuraSolidWorksPlugin\CadIntegrationUtils\ComFactory\PyWin32Connector.py", line 25, in CoInit 2018-02-21 14:22:05,455 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: pythoncom.CoInitializeEx(pythoncom.COINIT_MULTITHREADED) 2018-02-21 14:22:05,456 - DEBUG - [(1488)-MainThread] UM.Logger.logException [86]: pywintypes.com_error: (-2147417850, 'Cannot change thread mode after it is set.', None, None) 2018-02-21 14:22:05,456 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.startApp [49]: Trying to get new class object.. 2018-02-21 14:22:05,544 - INFO - [(16052)-Thread-3] UpdateChecker.UpdateCheckerJob.run [70]: Found a new version of the software. Spawning message 2018-02-21 14:22:09,166 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [366]: Mayor version is: 24 2018-02-21 14:22:09,167 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [367]: Minor version is: 3 2018-02-21 14:22:09,167 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [368]: Patch version is: 0 2018-02-21 14:22:09,167 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getFriendlyName [103]: revision_major is: 24 2018-02-21 14:22:09,168 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.startApp [417]: Started: SolidWorks 2016 2018-02-21 14:22:09,169 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [366]: Mayor version is: 24 2018-02-21 14:22:09,169 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [367]: Minor version is: 3 2018-02-21 14:22:09,169 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getRevisionNumber [368]: Patch version is: 0 2018-02-21 14:22:09,171 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.closeApp [424]: Rolling back changes on app_frame. 2018-02-21 14:22:09,172 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.closeApp [431]: Rolling back changes on app_instance. 2018-02-21 14:22:09,174 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.closeApp [441]: Closed SolidWorks. 2018-02-21 14:22:09,174 - INFO - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.getOpenDocuments [479]: Found 0 open files.. 2018-02-21 14:22:09,175 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.checkForBasicFunctions [239]: Looks like we opened SolidWorks and there are no open files. Let's close SolidWorks again! 2018-02-21 14:22:09,223 - DEBUG - [(1488)-MainThread] CuraSolidWorksPlugin.CadIntegrationUtils.CommonComReader.postCloseApp [71]: postCloseApp.. 2018-02-21 14:22:09,223 - INFO - [(1488)-MainThread] CuraSolidWorksPlugin.SolidWorksReader.isVersionOperational [298]: Success! Installation of 'SldWorks.Application.24' seems to be valid! 2018-02-21 14:22:10,588 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin CuraSolidWorksPlugin 2018-02-21 14:22:10,649 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin OrientationPlugin 2018-02-21 14:22:10,665 - INFO - [(1488)-MainThread] UM.PluginRegistry.loadPlugin [238]: Loaded plugin ZOffsetPlugin 2018-02-21 14:22:10,678 - INFO - [(1488)-MainThread] UM.VersionUpgradeManager.upgrade [113]: Looking for old configuration files to upgrade. 2018-02-21 14:22:11,594 - DEBUG - [(1488)-MainThread] UM.Backend.Backend._logSocketState [173]: Socket state changed to Listening 2018-02-21 14:22:11,612 - INFO - [(1488)-MainThread] UM.Backend.Backend.startEngine [74]: Started engine process: C:\Program Files\Ultimaker Cura 3.2\CuraEngine.exe 2018-02-21 14:22:11,614 - DEBUG - [(1488)-MainThread] UM.Backend.Backend._backendLog [90]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 3.2\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '-j', 'C:\\Program Files\\Ultimaker Cura 3.2\\resources\\definitions\\fdmprinter.def.json', '']
Edited by AbeFM
You catched an interesting bug!
Everything works fine, but I'm asking SolidWorks something after closing it. Therefore no one to talk with.
I'll look tomorrow into the code and look for a solution.
Additionally, can you answer me one question maybe?: If you export an STL manually and open it in Cura, is it correctly orientated?
(For the next time do not copy paste content from the log, but upload the file directly. If it is to huge, close Cura, remove it, reproduce the bug and close Cura again. The new file should be smaller. Forum maintainers could rate this amount of text as spam.)
What do you mean by "correctly"? When I do that, exporting STL from soildworks, +z is +z. Frustrating because their "top" plane
is not the X-Y plane as one would expect. So when I draw a "top down" view as if looking at the print bed, I have to remember to do that drawing on the "front" (X-Y) plane.
Things drawn on the "front" plane come out on the printbed after exporting. Attached find an STl, forum won't let me post part.
IkeaAppleSlicerBottom_SPRITTA.STL
Edited by AbeFMAlright, so the autorotation feature in the plugin is useful for you.
Now I looked again into your log and noticed you are using SolidWorks 2016. Somehow I can remember, that someone mentioned using SolidWorks 2013.
The reason I'm asking is, that I do not know for which SolidWorks versions this rotation is needed.
If I would know that the misorientation is there since SolidWorks offers STL export, then I could do the re-orientation just generally.
At the moment I'm checking whether SolidWorks >= 2016 is installed.
Top Posters In This Topic
121
47
29
14
Popular Days
Feb 12
19
Feb 14
18
Feb 22
16
Feb 13
16
thopiekar 121 posts
XYZDesignPro 47 posts
AbeFM 29 posts
drayson 14 posts
Popular Days
Feb 12 2018
Feb 14 2018
Feb 22 2018
Feb 13 2018
Popular Posts
AbeFM
Oh, ah!So what is "3D-printing" versus "Solidworks" - neither is what I would associate with "quality". I assumed that WAS the orientation adjust.
XYZDesignPro
Without actually going through all of the steps you have outlined, I can tell you for sure that the setting for STL, 3MF and AMF export out of SWX 2018 all carry over. The differences are only with r
XYZDesignPro
Hello Thomas hope all is well. Just thought I'd drop you a line to let you know that your plugin is working very well in Cura 4.0.0 and SolidWorks 2019 SP2. I really appreciate that now it has the a
Posted Images
AbeFM 35
Um, I can "disable* the old plug-in, but not "uninstall" it, is there a chance that therein lies my problem? What (minimally) should I do to make sure I'm fully rid of the old one?
utterly wrong post.
