what you could try is instead of “Save to removable drive” use “Save to disk”. A save dialog will pop up and it should allow you to change the name and extension of the gcode file before saving. There is no way to default to .g instead of .gcode
Thanks for the reply!
I tried this before my initial post. Still will not change the extension to just .g
As this is my first 3d printer is this out of the norm for a printer to only read .g files? Frustrating!!
ahoeben 1,849
