tinkergnome 918
Is it possible to limit the areas in which support is added in Cura?
It's not very convenient (yet) with Cura, but it's possible. The keywords are Support Mesh & Anti Overhang Mesh (follow the link)
tommyph1208 55
You cannot directly decide where support is generated, for that you would have to disable automatic support entirely, and instead manually add it (model it into) your 3d model.
I have however found that you can typically get fairly close to what you want, but playing around with the support settings, the "everywhere" or "buildplate only" options obviously, but also tweaking min x, y and z distances, as well as the support pattern and overhang angle required for support to be generated.
