T0 is being set to 220, 235 and 245 while T1 is being set to 205, 210 and 220 despite all my settings in the profile and the material for print and standby being the same.
That's the intended behavior for multi extrusion prints. There are more than this two temperature settings. It's an outstanding feature of Cura (IMHO). I suggest to enable all settings in the material section.
Which kind of printer do you use? Have you choosen the correct printer model in Cura? I ask, because there are additional settings in the printer profile (not visible at the user interface) that define the speed at which the nozzle heats up and cools down as well as the minimal time an extruder has to be inactive before the nozzle is cooled. It seems that you are using values that are not suitable for your printer?
hmmmm, that's pretty rubbish then. I'll have a look at the printer definitions, my printer isn't listed as it's a CoreXY design that I scratch built so I just chose Custom FDM Printer.
Failing that I guess it's back to Slic3r as that sliced the same job without any issues. I remember now why I stopped using Cura last time when the developers started adding hidden "features" and removing basic functionality without telling anyone.
tinkergnome 926
