tinkergnome 918
I found this repository at GitHub?
If this is the right one, it's probably better to get in contact with the developer via GitHub.
Jeffg1 2
Bump. I want to learn more about how the Siemens NX macro works! I assume it is set up similar to an NX Journal. If so, where is the macro file, and can parameters be edited, such as triangle and edge tolerance for generating STL? Also, looking to learn how to uninstall the macro so I can re-install from the Cura interface.
Thanks!
Jeff
