Okay I don't think this is possible. That only work on infill. Not support. This is what I was thinking of:
Also I thought you could break your model into two parts and have per-model settings set the support pattern but no. That's not an option either. You can certainly have more or less dense support on different parts of your model but not different support patterns.
gr5 2,332
Maybe. I haven't tried it but you can open a cube or cylinder with cura and scale it to any shape/dimensions then use that to alter slicer settings for your actual part. I'm not certain you can vary support settings using this technique but you probably can.
