Why does my first layer isn't showing when I use support?
Posted
· Why does my first layer isn't showing when I use support?
Hi. My guess is that the bottom surfaces of the model are not absolutely flat or that the bottom surfaces are not completely aligned with the build plate. What happens if you lower the model very slightly into the build plate (i.e. set model position z slightly -ve)?
Posted
Well, the problem is that the model is perfectly flat. It has been cut in netfabb. And if I don't put the support material, I don't have this problem. It only occurs when I use support
Pretty weird huh?
burtoogle 506
devilflash 2
Pretty weird huh?
