Posted (edited) · My first Mask: what causes the print lines?
I've just printed my first mask, in a smaller size to make sure it all works.
The pic is lit from behind and clearly shows the print lines. I rather enjoy what many would regard as a fault - almost like a Maori moko (facial tattoo).
I'll do more research and maybe print a full-size one as in the other pic, and paint it afterwards. All credit to Jacob/JTM: https://www.thingiverse.com/thing:1013350
I would like to learn how to avoid those print lines.
These are the Cura 2.3.1 settings I've used:
- UM2+, PLA, 0.4mm nozzle, normal quality.
- Layer height: 0.1mm
- Wall thickness: 1.05mm
- Top/bottom thickness: 0.8mm
- Infill density: 20%
- Infill pattern: Grid
- Infill layer thickness: 0.1mm
- Enable retraction: On
- Print speed: 50mm/s
- Travel speed: 120mm/s
- Print cooling: On
Thank you!
