Posted · AA core nozzle replace
I have some spare nozzles for the UM3 Core, you can contact me if you want (i see you are in Europe).
Just be aware that it's also quite easy to break the core when you change the nozzle (it's not designed to be changed)
    Hello
    I just bought a Hardcore from 3d Solex for my UM3
    With this core you can easily change nozzle,
    I choosed the option wit: 0.25/0.4/0.6/0.8 and 1.0 nozzle
    They also sale the Everlast nozzle, wich you can use with abrasive filament.
    Have a nice day
    Matthieu
    Thank you for NON responding to my messages.
    Posted (edited) · AA core nozzle replace
    I did a mistake with an abrasive filament.
    It is possible to change the nozzle ?
    It is now, or in the future, 0.4 nozzle as spare part for UM3 ?
    For UM3 Cores changing the nozzle could be possible but noone makes nozzles that could fit. The problem is that um3 cores are designed as stuff you toss away if fails, you know like a cartridge. Why can’t you swap the nozzle? Well, you would need to heat it, use tools, and be careful with many parts. Also the biggest issue is that noone makes nozzles for it. Maybe now that um3 step files are there aliexpress china cloners might make some.
    So, Officially I highly doubt UM will ever release cores with easy nozzle chanes. You know, for big $ companies is easier to change a cartridge/core, pay 100€ & switch it to keep working than using time to manually change a nozzle.
    On the other side the prices for the core components are really low for a cartridge that has heater, sensor, black peek as plastic holder, and their heat break design is quite neat.
    If you want to remove the nozzle @gr5 made a video and you will see that isn’t a easy adventure
    https://youtu.be/Ln_tMz8Dwd0
    But remember that noone makes that nozzles. At least for now.
    Edit. Changed it to ‘code’ because the video gives a error linking it here. So copy/paste it to see it
    Replied to your pm (sorry i was away a few days, yes i take some days off sometimes)
    Hi, is there anyone producing these nozzles? I have one that seems very worn down, and i'd like trying to replace it before tossing away the printcore..
    Edit: i just found https://www.3djake.com/brozzl/hardened-steel-nozzle-for-ultimaker-3-aa
    has anybo
    dy tried it?
    Edit2: seemingly amazon also sells brass nozzles for UM3.. any feedback?
    Edited by paoletto
    It is really not recommended to change the nozzle on the print core. You risk your whole print head if something goes wrong and filament leaks out on the upper part of the nozzle.
    The print core itself is one part and it is not made to replace a worn out nozzle. But it is doable with some work.
    My PC nozzle is very very worn and is underextruding, i don't think i can keep using it as is, so it's either trying it or throwing it 🙂
    Sure you can try it, but be warned that you retighten the nozzle as hell to avoid any leakage.
