Clean clogged printhead on Ulitmaker 3
c3038354
Posted · Clean clogged printhead on Ulitmaker 3
Hello,
I started a print on our Ultimaker 3 and after 20 minutes a "blob" of PLA had built up around the nozzle. As the printer apparently had printed continously on one place, the PLA entered the printhead and everything is clogged.
On a side note, I started the print on our second printer and it printed fine, so it wasn't the file.
I can't remove it mechanically while applying moderate force. Do you have any tips for cleaning up the printhead in this case?
External view:
Internal view:
Is there a tutorial how to disassemble the printhead?
    I have no tipps about removing it other than heating the print core and carefully prying the filament from the nozzle.
    But you should definitely contact your seller and ask about a replacement of the nozzle silicone cover.
        • 6 replies
