Modifying Extruder "Steps Per Unit" Doesn't seem to work...
Posted · Modifying Extruder "Steps Per Unit" Doesn't seem to work...
Recently upgraded to some beefier steppers which also have half the step size. Default steppers run 1.8 degrees per step, my new ones run .9 degrees. I adjusted the values in configuration.h, and everything seems to do as I expected. The X, Y and Z seem to all have scaled properly. The problem is that the extruder is only putting out half the needed volume, and no matter what number I punch into the setting, it doesn't seem to have any effect.
Can someone please tell me what I am missing?
