Ultimaker original +header
jean-pierre
Posted (edited) · Ultimaker original +header
Hi , I'm currently working on a project with the ultimaker orignal+ , and i wanted to know if it's possible to disable the Temperature's check from the ultimaker.
If it's possible, I would like to change the header of the ultimaker original +.
Thanks
    Everything about the printer is cntrolled through its firmware, Marlin... You can grab the latest version of that from their website or GitHub:
    http://marlinfw.org/meta/download/
    Make the changes you need in the files contained and upload your modified firmware to your printer using eg. the Arduino IDE
        • 4 replies
