kmanstudios 1,120
4 hours ago, rajilpahuja said:Yes its pretty tough with these materials @kmanstudios somedays u feel you mastered them somedays its like you keep finding whats wrong, specially when u change anything in the setup, even when you will use different nozzles u will need to recalibrate the flow, as you know generally there can be tolerances with nozzles, so then its back to tests, optimize the flow rates again, its just a small example i am giving, these materials dont like relatively less than good tuning at all, in one of my twitter posts i mentioned that its better to be using Ruby nozzles, as i found out that brass nozzles wear out quicker when printing this high temperature, or you need another material which can take high temps, these are just some pointers i can give of the problems that may come.
No, My "Huh" was because all I can see is text:
"The Dark Knight Rises" made in Ultem 1010 Black from @3dxtech truly strong sharp feels like metal @neotko @Ultimaker @77bergkamp19 @VisionMiner @BondtechAB @gr5org #3Dprinting #Batman #JusticeLeague pic.twitter.com/JrcVpPQ49Y
— 3damss (@3DAMSS79) March 27, 2018
I see no image or anything other than the above text.
rajilpahuja 38
Thanks for the wishes sometimes they are really needed, i will try my best to bring the best things on the table for HT
