TOPIC FOR PRINTING HT FILAMENTS ( PEEK/ULTEM 1010/ULTEM 9085/PPSU/PSU) ON UM2+
Posted · TOPIC FOR PRINTING HT FILAMENTS ( PEEK/ULTEM 1010/ULTEM 9085/PPSU/PSU) ON UM2+
I wish you lots of Luck, it will be a very hard journey as these materials are very difficult to master but when you do master them there will be nothing more satisfying, in future i will be bringing out a kit for HT and right equipments so more people can use these, will just add a nice print i Did in black Ultem1010 :)
4 hours ago, amedee said:
Should not be too much of a problem to add that to the builder...
:)Well this guy might be buying a UM2 so it might not matter.
Posted (edited) · TOPIC FOR PRINTING HT FILAMENTS ( PEEK/ULTEM 1010/ULTEM 9085/PPSU/PSU) ON UM2+
Huh?
Edited by kmanstudios
@rajilpahuja Thank you for the positive outlook. I wish you the best in creating and fine tuning your experiments to bring the community highly advanced upgrades for these engineering and medical plastics.
I like the advantages of the UM2 but i haven't heard back from the seller. My options are still open to both the UMO+ and the UM2 with your generous recommendations. Right now its boiling down to the initial cost since the used UM2 is less than the UMO+ Kit. This can change as new opportunities arise
7 hours ago, kmanstudios said:
Huh?
Yes its pretty tough with these materials @kmanstudios somedays u feel you mastered them somedays its like you keep finding whats wrong, specially when u change anything in the setup, even when you will use different nozzles u will need to recalibrate the flow, as you know generally there can be tolerances with nozzles, so then its back to tests, optimize the flow rates again, its just a small example i am giving, these materials dont like relatively less than good tuning at all, in one of my twitter posts i mentioned that its better to be using Ruby nozzles, as i found out that brass nozzles wear out quicker when printing this high temperature, or you need another material which can take high temps, these are just some pointers i can give of the problems that may come.
    Thanks for the wishes sometimes they are really needed, i will try my best to bring the best things on the table for HT :)
    No, My "Huh" was because all I can see is text:
    "The Dark Knight Rises" made in Ultem 1010 Black from @3dxtech truly strong sharp feels like metal @neotko @Ultimaker @77bergkamp19 @VisionMiner @BondtechAB @gr5org #3Dprinting #Batman #JusticeLeague pic.twitter.com/JrcVpPQ49Y
    — 3damss (@3DAMSS79) March 27, 2018
    I see no image or anything other than the above text.
    And i get this
    That is so weird. I am glad you put it back up. Do not know what changes you made, but I can see it the last post just fine now :)
    Thanks!!
    Thanks!!
    Btw this print has something special, this uses the ironing function from Cura, people get jitters using this in HT, first time i failed too, but tuned it and it came out beautiful ?
    agreed!
    Rajilpahuja - Your "Bondtech BMG extruder on UM2+" is a direct drive version using an E3D style print head.  I have searched thoroughly and cannot find a mount configuration for BMG+E3D on UM2 style printer.  Is this your own custom mod?  If so, can you share CAD model or share what base UM2 E3D mount you modified?
    Hi There ,
    I gave the mod to bondtech ..... you will have to contact Mr Martin there .... i think he will be happy to provide you this ..... in the meanwhile i will search for the file as well .... it was made on my old PC so i will need to look at the backups .... but i am sure martin has it .... and will make this for you ..... 😊
