Need a easy setup to put static IP address on the printer on wired
dzappa
Posted (edited) · Need a easy setup to put static IP address on the printer on wired
There is not an easy way to do this, the workaround requires enabling the developer mode (this makes the printer very insecure).
And then using the Linux command line, here is some guide for using connman to do this: https://communities.intel.com/thread/60242
There are some more people struggling with this though: https://ultimaker.com/en/community/50136-configuring-static-ip-address-for-wifi-connection or https://ultimaker.com/en/community/27035-how-to-set-ip-address-without-wifi-or-dhcp
So please consider if configuring a static DHCP lease is an option instead.
    • 6 months later...
    Posted · Need a easy setup to put static IP address on the printer on wired
    I would also request an easier way to do this.  Particularly if using the IP address for history reporting, it would be nice to rely on this retaining a static IP.
    I wanted to do this without using DHCP but eventually when I tried the DHCP method I was like "well that was easy!  I should have tried that first!".
    Having said that - if you don't know linux maybe it's time to learn a little?  Maybe not.
    I agree that it would be great if you could set the IP address from the control panel.
    I need to put an static IP address on a Ultimaker 3 extended. We are using this machine on a special network in my company so i can't play with the DHCP.
    I try to start the wifi setup to get the hotspot of the printer then I go in with SSH, I edit the /etc/network/interfaces file but nothing change. The printer take the APIPA address (169.254).
    Can someone help me ?
    Thanks a lot
    Regards
