How do I know what is the current firmware version? Ultimaker 2+
Posted
· How do I know what is the current firmware version? Ultimaker 2+
don't know what the latest firmware is, as I use tinker firmware myself.
If you can't update from cura 3.0.4 you can try to update from an older (15.xx) version of cura. You can install the 15.xx version next to the new cura versions.
Just select "install custom firmware" and select the correct .hex file in the folder of your cura 3 installation. (C:\Program Files\Cura 2.7\resources\firmware)
In general there's no real point to update the firmware on a Ultimaker2 with every cura update, as there are not much developments in it anymore (compared to the UM3, where you should update firmware....)
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
ultiarjan 1,223
