kmanstudios 1,120
1 minute ago, Marco_TvM said:Random Generation of Blobs?
I think that would be possible
Well, since we are wishing, I will repeat, give me a reason not to lust after a MarkForged. Either the ability to lay continuous fibre or at least reliably inset a CF plate and seal it (note - by 'sealing' I mean laying a border of filament to take up any space between the inset stiffener and the surrounding material)
J
I'd look into having the option for the user to mount the material on the side with the extruder towards the front. making it easier to load the material. have a heated enclosure as part of the machine. have a way to open the extruder for easy access for cleaning the feeder wheel whithout having to unscrew the whole thing. Four point bed levelling instead of the three currently used.
Make the front frame a bit wider making it easier to take out the glass plate.
Add a rubber mat, removable floor inside the printer making it easier to clean out the bottom of the printer.
just a few ideas
Why would you want four point leveling as 3 points define a plane? To have an overdefined system in order to reduce errors?
I'll just leave this post here... (big news!)
Yeeeeaaahhh finally !! So I see a much bigger print area, same print core system as UM3, I see doors ! and new HMI!!!! I think touch screen, with no buttons. Sadly it seems there is no top cover.
9 hours ago, ksmilejun said:what do you means this?
That's a mystery, you find more speculations at this post:
and this seems to be the release date:
nallath 1,120
It's not just one parameter. All of them influence eachother. Just changing the temperature tends to be insufficient. It's something you can do by interns, but that's also not the way to stay ahead. I'd much prefer that our experienced process engineers do the profiles
Marco_TvM 34
Edited by Marco_TvMLink to post
