Regarding the pausing requests, you can already pause your print using Cura, right? Do you mean using Cura Connect or in the traditional workflow? Regarding in between prints, by not confirming you have removed your print it will remain pending until you have, no? Maybe I didn't understand it, or perhaps I just already solved 30% of your UM4 wish listDear UltiSanta,
I have been a good boy this year and would like to see the following things on an Ultimaker 4 system:
- Larger build volume because, well, I like big things and I cannot lie, other guys might deny, teeny weeny things can be done by every other thing.....
- Properly enclosed build area to remove heat issues on the whole.
- Smoother ops between firmware and software. While firmware accepts 'PLA' (or other various substrate) regardless of color or type Cura wants to choke on it requiring a manual override when printing even though all the settings are the same when you are slicing (unless you change them of course), So if you are using presets, does it really matter what color it is?
- A pausing function between prints to allow for cleaning ops as I change plates between each print
- A pausing function During prints to allow for cleaning ops as long prints can accumulate or cook hygroscopic materials and require cleaning
- An actual resume print after some sort of failure would be cool, especially on those long prints of days and days and it chokes at the last few hours
- And, finally, a dilithium crystal matter/antimatter mix chamber for off grid printing when Armageddon hits
SandervG 1,518
