when you say a new PLA I assume you mean a different manufacturer, I have seen this problem (with the same manufacturer) just by changing colour of PLA
I think they are called 'artefacts' they can be reduced/eliminated by lowering the print temperature by a say five degrees which should make a big difference
stu_le_brew 42
