kmanstudios 1,117
Forum is really bad today...eating replies and now will not even display a link properly. Grrrrrrrrr
Wow, that was a sloppy file. I am surprised you could get anything out of it.
I went ahead and remade it by 'tracing' over the master file and snapping at its vertex points. I am not sure if it could have been fixed. I have no idea how anybody ever got anything printed off that.
gr5 1,872
It's not your fault - it's a bad model - you might be able to see this if you look at it in xray mode - anything in red is a problem (like extra walls inside the model). Unfortunately you didn't create it so not so easy to fix.
First I would try the "mesh fixes" options in cura - the top few ones - check those to see if it fixes it.
If not then there are some tools out on the web that will fix it for free. If you manage to fix it please upload your fix as a remix on thingiverse to this model so other people can download the fixed version.
netfabb used to have a free web service that repairs meshes. Try that first - I think it's still there. It's the easiest tool I think that usually works. If that doesn't work there is meshlab but you'll need to find instructions first for repairing non-manifold meshes. or just google "3d mesh repair tools"
