try it multiple times, again and again, I have several cards with the same issue, or use an usb/sdcard extension.
Thanks, I figures out the problem.
The cars was connected to the PC with a card reader..
Direct plugged in SD card worked fine.
Card reader, is what the name indicates, just a reader I think.
- 5 years later...
gr5 2,094
I'd get another SD card.
Are you sure you don't have lock/unlock backwards regarding the little switch on the SD card?
