Posted
· Layer shift only when printing multiple models
By changing the way you print you put more stress on the Y axis and it is slipping. But the root problem is that one of the pulleys is loose.
There are 5 or 6 pulleys on the Y axis - you need to tighten the little set screw in each one. Tighten the hell out of that little screw - so much that the tool is twisting almost.
usually the most important one - the problem one - is the hardest to get to - one of the two pulleys on the short belt: either the one on the stepper motor or the one just above.
You might be able to tighten the one on the motor without removing the left rear cover but if you do have to remove the cover it's only one or 2 screws (depending how old your printer is).
Posted
gr5 2,225
More info about all this here:
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide
CHCP_Teen 0
Thanks a bunch! We'll try tightening everything next time we get a chance.
