change the density of the infill during the print on cura
eeem
Posted (edited) · change the density of the infill during the print on cura
Hi I am using CR-10 at the moment. A beginner. Tried to use Cura to set a particular infill for only a part of a model. Simply3D can use variable setting wizard, has Cura got something like that? I know there is per object setting, but I have to create many objects from one model. Or the swapatZ plugin? Thanks
Tom
    • 10 months later...
    Posted · change the density of the infill during the print on cura
    4 minutes ago, dbantner said:
    This plugin is no longer bundled with Cura. Is there anyway to get it in there?
    Yes it is, see Extensions -> Pos processing -> Modify G-code
    Ok, it is named "ChangeAtZ" now, but it has the same functionality that "TweakAtZ" had.
    Having said that, neither TweakAtZ nor ChangeAtZ can change infill parameters.
    Instead, use an additional mesh to modify the infill settings using per model settings.
        • 6 replies
