From what I gather, if you leave jerk and acceleration control at disabled, your controller will use settings that are defined in the firmware.
You might be getting better results because Cura sets the outer/inner wall speed at a rather conservative value, something like 50% of the print speed, where on the other hand Simlify3D might be using something like 80% of the print speed. So, if you have a print speed of 60mm/s, Cura will print outer walls at 30mm/s and Simplify3D at 48mm/s, which is a difference that is big enough to increase the effects of rippling/ghosting on a Prusa i3 printer.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
MatejEU 1
