CURA 3.0.4, CURA Connect on UM3: Third-party Material to Override Configuration... so many steps?
Posted
· CURA 3.0.4, CURA Connect on UM3: Third-party Material to Override Configuration... so many steps?
Kinda double posting that, so I will follow suit
Actually, if you use one type of filament (Say Blue PLA) and you have Transparent PLA loaded, it will still cause the issue. The problem is that all those are generic and the same, so, I am confused why the software has an issue with it when the firmware does not.
When I print off a USB stick, no issues. Same file going through Cura Wifi and Connect, gives the error message.
It is also a problem when you have any filament off the spool and in a separate dry box that prevents any reading of the NFC chip and you are forced to choose generic PLA or any other.
The upside is that I use that as a 'pause' to change plates, clean nozzles (can even do atomic pulls if needed), wipe with alcohol and also apply Papa K's Magical Slurry. THEN I configure the override and it goes about its business.
I have the whole process down to about 5 minutes between end of print to start of leveling.
kmanstudios 1,120
