I think what's happening here is that the firmware is trying to prevent you from pushing cold filament through a nozzle; the firmware does not know you don't have a hotend to go with the extruder motor.
I think there's a gcode command to lower the minimum nozzle temperature at which the extruder motor will try to extrude. You could put that in your start gcode.
That should be M302... I will try
Update:
Tried and it started printing without heating nozzle and tried to extrude the filament with first extruder. 2nd one didn't work...
ahoeben 1,849
Edited by GuestLink to post
