Posted · Ghosting when slicing with Cura
Hello,
I'm having issues when I slice with Cura I'm seeing some weird ghosting/artifacting in my prints, I done a test by copying the settings as best I could over to S3D (Speed, Shells, Top and Bottom layers and etc) and got pretty much no ghosting.
Any idea on what Cura is doing?
I used the stock CPE profile for Ultimaker 2+.
Photo of Cura 3 print (it's way more noticeable when it was in the printer under it's lighting.
Photo of S3D print
    What I see in the first image looks like the infill showing through. What wall thickness are you printing with? Have you played with the "Infill Before Walls" setting?
    the default 2 walls, I have not played with "Infill Before Walls" yet but will give it ago.
    Could you please post a link to the model? Thanks.
    https://www.thingiverse.com/thing:853358
    I did reprint the model with some settings changed 3 wall, less infill, different layer height etc, and got the same results, here is the project file if that's any help.
    https://drive.google.com/open?id=1K9Wk1ELcb7qFxw9EmmBwrbBH9WI5TY_e
    Posted (edited) · Ghosting when slicing with Cura
    Made no difference.
    Just want to bring this back up with more testing Cura is doing something weird and spent a good 4 days trying to work out why with no luck, This infill showing through effects PLA, ABS and really shows up in PETG the most.
    eg:
    Cura 3.1
    Simplify3D 4
    Both had the setting matched as best I could.
    35mm/s Main Speeed
    25mm/s Outer wall
    245c nozzle (PETG)
    75c bed
    100% flow
    4.5mm retraction
    5% infill overlap
    tried to match the slow down speeds for layer time as well the best I could.
    I don't think its just me as A friend got a UM3E and is also seeing this just getting permission to post one of his photo's here and i'll add if I can.
    Edited by Skippy7
    Search for a thread about "Zebra Stripes". they address this issue in that thread.
    If its its to do with the stepper drivers and the TL-Smooths will fix it why would other slicers like S3D and Slic3r PE that I tried lessen the effect alot especially for PETG?
    That would be above my knowledge base....sorry......There are those who would be far better to answer that. I just can reference threads that I have seen. When I saw the pic, I knew what was meant by 'ghosting.' Plus, my experience has only been with the UM3X printer. Sorry I could not be of more help :)
