Thanks for the 3.0.3 I'll load and see if that is OK.
There is no change and this problem still exists.
From the Fusion end I am able t select Cura as a custom 3D print app. But in doing this every model I send to print opens a new instance of Cura.
Add "--single-instance" as a command line argument to Cura.exe in Fusion.
1
Thanks for this, could you provide a bit more info on how to do this? I can't find anything I can edit this into within Fusion???
Maybe a screenshot if possible
I don't have/use Fusion 360, sorry.
- 1 year later...
I have the same problem since I updated to 3.6.0. Has there been a solution? Seems to be in the Cura.exe file,
robinmdh 99
Well here is the windows 3.0.3
Let us know what happens and if no Cura dev comments I'll pass it along!
Edited by GuestLink to post
